Whilst I was looking for cables the other day I spotted the Magura hydraulic clutch conversion on the Venhill site.
It looks really neat however the longest pull available seems to be 107mm and a quick measure leads me to believe bevels need > 117mm.
I have to say it is a really neat idea; If you look at the clutch cable routing on a GTS below and consider the Brutus (as in Popeye's nemesis) like forearm requirement of the clutch on many bevels, it looks very attractive...
What may not be apparent is the narrow radius turn the cable has to make immediately after exiting the lever, followed by a turn the other way to go under the tank; Not good.
The hydraulic cable would solve this in two ways:
Should my numbers come up I might take a punt on one of these however the pull shaft will need cutting & elongating, which might be tricky.
Has anyone had experience with the Magura conversion on a bevel or any other bike?
- the hydraulic pipe is thinner (think bicycle hydraulic lines for brakes) so will be easier to route
- the fluid isn't adversely affected by bends :scratchhead:
