Flatline
This is the rear wheel '91 750ss.
My bearing puller will not hook under the bearing, so slips out
I'm unable to use anything from the other end to drift the bearing out
There are 2 cut outs on the spacer, one can be seen in the photo
So i need a 2 leg puller similar to the one in the photo, but smaller.
Or does the hive mind have a solution?
