Basic electrical question
Everclear
Kicked out for being a knob
This is embarrassing it's so Electrics 101 - but then again I do embarrass myself a fair bit so what the hell.
A mate (yes I do have them) asked me to rig up LED strips on his son's Ninja 300 (I know, I know ... he's young and stupid). I warned him I know SFA about electronics but he seemed to think my bike ownership qualified me.
So rigged them straight from the battery and cut out a switch from a lamp cord (one of those that is in the cord to the lamp, not the lamp itself). Worked fine for a few minutes until the switch fried - even I figured out that the switch was handling voltage from the plug in adaptor which only had a 4V output (but it wouldn't surprise me if I'm even wrong about that).
So, can anyone, along with laughing at me , suggest what appliance laying around the house I can nick a switch from that will work and not shit itself?
TIA.
TIA.
LED's have a near zero internal resistance, but need enough voltage to overcome the PN junction. Typically they are joined together in chains and then have a current limiting device. The most basic of these is a resistor.
So each vehicle LED lamp is designed to work at a particular voltage. Say 12vdc.
It sounds like you've not only fried a switch, but perhaps also the LED lamps.
Basically I need more information on the actual lamps you used. Make, model and a link to the website or instructions
Are the strips from that supplier?
Yes they are. The other side is just 3M tape.
That's a small section I trimmed off.
That's a problem.
They can ONLY be cut at the copper coloured point.
It appears that the one photographed has been cut off at the wrong point.
Bin it.
OK;I'm familiar with that design/layout.
It just needs 12Vdc supply.
The on-board resistors are limiting the current.
You need any 12V switch, rated at the appropriate current for however many you intend connecting in parallel.
That's a problem.
Bin it.
Thanks mate, just have to find a switch as the boy's budget is zero $
Thanks @AirCon for the help. I ended up just buying a switch from an auto store as I knew the young bloke was keen to strategically turn the lights on. 🤦‍♂️
He thought the end result was "fcuking ace" - I thought it looked bloody stupid but there you go, he's happy.
Cheers.
Have you got a photo of the final install with the lights on?
Even worse, I think he would have had them brighter if possible - and I didn't take a photo from the front where there are strips either side of the radiator, so you could feel dirtier!! :ROFLMAO:
Heat is the killer for LEDs, so perhaps your weather and thermodynamics will save the day.
