bigchunk
Hello folks, just cured a wee problem on my 999s (07 model) and thought i would share it with all out there just in case you would like to check your bike for the same problem!!
To cut a very long story short (including trying to find out what the hell was wrong in the first place when the dam thing would not start one afternoon!!) i took off all the fairings and found that my fuel injection relay was positioned on the left hand side of the bike at the very bottom of where the fairing sits and it was upside down in this position, needless to say after being a year and a half old, and although very rarely out in the rain the relay was in such a place and position that it, and the plug were very badly corroded!!
Purchased a new relay (from the Mercedes garage down the road from me as it is the same one used in one of there own models and it was a Monday so DG was closed!) cleaned up the multi-plug and then re-positioned the plug and the relay further up in the plastic unit thingy and also turned it up the correct way round, so that at least this time if it gets a bit wet in there it wont act like a dam water magnet!!!
If you have a 999 its worth checking out, as you might get stuck out in the middle of nowhere if it wants to give you a scare like mine did!!
