Hi Derek, thanks for the reply, the problem came on suddenly, the fuel light came on (a bit early) and it started misfiring as if running out of fuel, I filled up but the problem remained, I checked the coolant sensor by dangling it in a pan of water and checked the resistance with an ohm meter as the water temp. increased the values were in line with spec. The one thing I did notice was the fast idle switch was stuck on which I freed off but don't know if this would leave a lasting problem. I can rule out the whole tps injector part as I put a replacement job lot on to see if that solved the problem. The ecu is a 1.6m does the trimmer roll over i.e. go leaner,richer, leaner as it is rotated, I understood it to have 270 deg. from fully rich at full anti clock to fully lean at fully clockwise. I haven't checked the fuel press. reg. yet maybe that's next. Any other suggestions warmly welcome, cheers, Dan.
