916 engine - what's it worth?
thomp1983
Hi, does anyone have any ideas what a bare 1998 bip 916 engine is worth? It's fully serviced and showing 26k. It'll be having the valve clearances checked and done if required once removed. I'm looking to fit a 1098 engine so ill be keeping all the injectors, throttle bodies and bits it'll just be the engine, starter motor and clutch
Thanks
chris
I have no idea what the engine might be worth but I doubt if you'll get away with fitting 916 throttle bodies to a 1098. The 1098 is a Testastretta engine and is dimensionally different. The throttle bodies have a much bigger elliptical bore. So even if you can fit the 916 throttle bodies the engine will be strangled and down on power.
you are right derek in that ill need to use the 1098 throttle bodies, a custom airbox is required to mate the lower 1098 airbox to the 916 top half but the rest of the 916 injection system does the job
I'll be interested to know how you're going to marry up the linear TPS on the 1098 throttle bodies to the 916 electronics. Or is there a way of fitting the 916's non-linear TPS to the 1098 TBs so that it's also adjustable?
I just had a quick read through some of it and see that that particular conversion is using a custom EPROM to use the linear non-adjustable TPS. Good luck with the air box mod.
I am looking for 916 engine when you decide to Change let us know cos I would be interested in the engine but it might be out of my budget but give me a pa when you have an idea there are a few on ebay just now but to much money for me there was a couple on ebay for around 600-900 but now the ones on ebay are 1100 or more
Pm sent
