888 electric/charging issue...
Leftus
I'm aware of the newer-Monster recent charging thread but I'm not sure what applies to my 888... so the day after a lengthy ride out (260 miles) my 888 starts and gets me 10 miles before stalling, no lights/horn etc., bump start gets me almost home with a dead battery. I recharge the battery, start it and put the meter across to see no increase in voltage with the engine running, increasing engine speed has no effect. Suspecting the Reg/rec a visual shows severe burning at the yellow wires junction box from the stator to the RR... the battery 30A fuse is also burnt, so I gayly order a new MOSFET reg/rec. I have just fitted it, connecting to the bike's yellow feed wires using 15A electric connectors to ensure a longer lasting connection, ensuring the two earth leads are securely connected, recharge battery and then start the bike... a check across the battery reveals fuck all charging to the battery with no difference to the voltage when engine speed is increased!! Help!! Could someone outline how to check for an output from the stator? I have a multi meter but would appreciate a step by step guide to using it to test the stator would be a great help... and if the alternator is producing (I think 15V/1000rpm) any hints on what to look for? If the alternator is goosed is there an aftermarket superior fitment?? Help!!
Please show me your multimeter?
I'm not a motorcycle electric specialist, more of an electronics guy who fixes nearly everything I come across.... as a challenge.
My advice may contain nuts and is free, so don't expect any compensation if your bike catches fire.
Using a good Multimeter measure the resistance of the two yellow wires to each other.
So that's the Rectifier / regulator disconnected and just the two yellow wires coming out of the engine...
What is the resistance in Ohms?
I'd expect the resistance to be circa 2 to 4 Ohms.
Then we need to check that the Stator wires haven't broken down (due to heat) and shorted down to the chassis...
So using your Mega and the 1000V setting check the earth leakage resistance... chassis to either or both Yellow wires.... it should be +20,000,000 Ohms.
I have a 907ie which has the same charging system as the 888 although I too have changed to a SHindengen Mosfet regulator. The alternator is a single phase 2 wire and as aircon says above measuring across the 2 yellow wires you should see a fairly low ohms resistance, which if I remember right was actually slightly less than 2Ω, but certainly in that region. If the stator is open circuit the meter will read infinity.
Like me, you probably haven't got the luxury of a Megger but if you set the meter to thr 20MΩ scale and measure across either wire and engine earth you will get idea if there is any earth leakage path.
The stator is the same as that fitted to the 90's 900/750/600SS or Monster and also the 916.
Electrex list these two :
Fits early Ducati models Generator - G93
Ducati Sport Touring ST2 Generator - G22
and Wemoto list this one, curiously also made by Electrex:
Ducati 900 SS (906SC2) 95 Générateur - Stator - Electrex Pièces chez Wemoto - Le Détaillant Numéro 1 En Ligne du Royaume Uni de Pièces Détachées pour Moto.
If the alternator is at fault, then it would be interesting to understand the cause. Though I've had several R/R failures over the years, the only time I've had a stator failure (which also caused a cascading failure of the R/R) was when the crank outrigger bearing (in the engine casing) failed and sent fragments into the stator, presumably knocking some of the insulation off and shorting the windings. As I've had that bearing fail in two different bikes in the last ten years, replacing that bearing is now a routine (but infrequent) preventative maintenance item for me.
Gents - thanks both for your input, really appreciate it, having retreated from the bike feeling lost last night I woke up with fresh eyes and before following your guidance with my lay man's multimeter I gave the components a good check, I found the positive terminal on the battery was slightly loose, the burnt fuse strangely sometimes showed continuity but mostly didn't, I shorted the fuse holder with wire, tightened the terminal, started the bike and saw the voltage across the battery happily rise fro high 12's to low/mid 13's volts depending on engine speed!! Happy days, I hope!? New 30A fuse on order... I suspect that the long ride of the day before the break down encouraged the positive terminal to slacken which in turn repeatedly broke the charging circuit frying the reg/rec feed block connector & wires until the fuse compounded matters by blowing thus killing the reg/rec, it having no place to dump the alternator output, whilst draining the battery... unless I missed something?? Thanks again chaps
... on another slightly related matter the wires to my dashboard battery light appear to be blanked off down near the reg/rec output block connecor, the battery light has never functioned whilst I have owned the bike, I assume this is because replacement reg/rec's do not have an output wire for the battery light - is this correct?
Yes, exactly.
That's correct. Most of them don't.
The placement of the 30A fuse on the early Ducatis is the not best. It is placed such, that in the event of the battery being connected the wrong way round it will blow and hopefully save the regulator but the bike remains connected to the battery. If the take off to the fuse box was on the other side of the fuse it would still protect the regulator but would also serve as a main fuse for the bike, so in the event of the fuse blowing or becoming disconnected the engine would stop.
A Stator will fail (and have done frequently) due to open circuit or high resistance to (or catastrophic failure of) the rectification / regulator device(s).
At this point the Stator turns into a very effective electric toaster. Having no bread to take its existence out on it loves turning the oil and anything else nearby into crispy bits... eventually including a self destruct. Unless a full strip down removes the crispy bits eventually these block an oil gallery and you get a even more expensive or possibly terminal engine failure.
The only way the connector block melted was due to excessive temperature caused by high resistance, when there should have been none (near zero) aka corrosion.
SO am I likely to have suffered crispy bits? The bike now charges so the alternator is working, will it be likely or unlikely that my engine will suffer without a strip?
I'd say unlikely as you are now working again and crispy bits tend to come from total breakdown , an oil change would maybe give you some peace of mind if you're worried
someone will correct me if I’m wrong but you can measure the output voltage from your stator by switching your multimeter to AC volts and applying the two probes to the (in your case) two terminals at the end of the yellow wires. The voltage will increase as revs increase. You’re only going to run the engine for a few seconds like this so it’s fine.
I'd just suggest you use insulated clips and not a friends fingers.... expected voltage could be over a 100VAC peak to peak at full RPM....
Note to self don't strip a live telephone wire with your teeth, especially if it is a busy line...... Doh..
