750SS Fuel Filter Change
CAT3
Boredom got the better of me again today & I thought I'd change the fuel filter on my 750SS. I've had the bike from new & I have never changed it so I suspect this may be the first time it's been done !:oops:
Removed the five cap head screws to remove the filler cap. Realised I could have left the two screws at the "10 to" & "10 past" positions as they don't do anything on these bikes, it's only the other three that secure the filler in place.
With the filler cap out it reveals the eight grub screws that secure the collar in to the tank itself.
Bit of a wipe out & grub screws removed. Should have put the bit of kitchen roll in before I dropped my 5mm Allen key in the tank !!
Grub screws out, quick pull & the collar is out ! Nothing like as bad a job as I was expecting after reading stories on some forums about how hard this is to remove.
Collar lifted out of the way & the old O-ring discarded.
The hardest part of the job I found was getting my hand in to lift out the fuel pump from these two spring clips that hold it in place.
New filter fitted, the correct way round & new O-ring fitted to the collar. I applied silicone grease to the O-ring & a thin layer of red rubber grease to the groove in the neck where the eight grub screws locate.
The reason for that is when you press the collar back into the tank it is very hard to know if it is in the correct position. If you press the collar down & look through the grub screw holes, (with a mirror) when it's lined up correctly you can see the ring of red grease. Simples ;)
With the collar almost fully in position now is the time to refit the weather seal, that way it won't disappear under the collar, out of sight ! I used a plastic scrapper to push it into position.
While holding the collar in place I tightened four of the grub screws to hold the collar in position. You can then just tighten the last four grub screws knowing they must be in the correct positions, (that is provided you checked the first four !!).
All the grub screws tightened, I applied a little grease to these screws prior to assembly, just makes it easy for the next poor soul !!
Filler cap ready to be refitted.
Job done (y)
Thought I'd cut the old filter open to have a look how bad it might be.
Also, I found these bits of crud at the back of the tank. If you look at the picture above showing the fuel pump clips you can see these bits in the corners under a bit of fuel.
Dear fellow Ducatisti!
As recently the fuel pump of my 1992 750 Supersport failed I was desperately looking for clear info on how to replace it (I first checked the two ingoing wires on current and earthing. All good there. So, assuming no issues on the remainders of the wires in the tank and on the fuel pump terminals, the fuel pump must had died). Although the Haynes workshop manual is helpful in explaining the steps to be taken, it lacks pictures of the situation in the tank and also some practical instructions on exactly how to remove the old pump. Thanks to this thread however (thank you Cat3!) I was able to get out the old pump and fuel filter and replace them. Very helpful!!
Nevertheless, along the way I encountered a few issues of which I think it’d be helpful for the community to share how I solved them.
1.) Preparation / parts
All necessary parts are available via Stein-Dinse in Germany. I ordered the fuel pump (Awkwardly branded ‘duc or die’. I hope that sucker will last a long time), fuel filter, fuel line, fuel line clamps, tank collar seals, bolts and screws via their website.
Before starting the replacement, I dry tested the pump to check its rotating direction with a 9V battery. For whatever reason the terminals on this duc or die pump are not marked with + and – to avoid wrong connection and thus ending up with a fuel pump rotating in the opposite direction. Do also note that a 9V battery will only gently rotate the pump. If you connect a 12V battery the revs will be much higher causing the dry-running pump to squeal heavily. That’s normal and will not be the case once pumping petrol.
2.) Removal of the tank collar (‘Ring nut’ in the Ducati parts catalogue)
Due to corrosion and debris buildup on and near the inner seal I could not get the collar out with my bare hands. Therefore, I made a lever which eases removal considerably. You’re all free to use the design of this tool if you promise to call it Ronnie’s Ducati Tank Collar Remover ;) Here are some pics of the tool loosely attached to the collar.
3.) Removing the old pump and installing the new one
See image of the clamps inside the tank holding the fuel pump in its position. Not easy to remove the pump with one hand protected by a thick chemical-resistant hand glove and not seeing what you’re doing. On top of that if there’s still some petrol left in your tank (as in my case) things get pretty slippery! I found out it gets easier when you use your right thumb to gently push open the front clamp a bit and then lift the pump with your other fingers. (The same trick applies when installing the new pump). Once out, I measured current on the positive terminal and earth on the negative, then applied the 9V battery on the work bench and it had indeed died. Knowing the trick with the clamp it was easy to install the new fuel pump / filter assembly again.
4.) Tank collar reassembly
After carefully but thoroughly cleaning the collar and the flange of the opening in the tank I put on the new seals and lubricated them lightly with a bit of grease. When installing the upper one (the one visible from the outside) make sure you maneuver it in its eventual position before reinstalling the collar into the fuel tank. As the diameter of the unstretched seal is smaller than the diameter of the collar this is quite a difficult job. The seal flips back pretty easily. I found out using all my ten fingers is necessary to force it into position. Nevertheless, once in place be both quick and gentle when pushing the collar back into the tank to avoid the seal flipping inwards again. Finger gymnastics it is! If managed successfully you’ll find out the collar will pop into the tank easily. Then, in order to avoid galvanic corrosion between the steel fasteners and the aluminium collar I applied some anti-seize for aluminium. You don’t want to be the sucker having to drill out seized screws from a petrol tank after having fucked them up with your little Allen key if you need to replace your fuel pump ever again :) Especially not the small 4 mm screws in the inner side holding the collar into position!
Done :) So, there you go. Some additional tips & tricks for this job. Good luck!
