CAT3
After waiting since September for my new rear sprockets to arrive I got fed up of seeing the chain & engine sprocket sat on my bench. So, I thought I'd at least fit the engine sprocket. As it was a bit of a faff to get it on my bench I thought I'd just do this little job with the bike on the garage floor. Makes you realise how good hydraulic benches are, espicially when your bones are getting old !!
There didn't look to be too much wear, but when you put the old & new sprockets up against each other you can clearly see the wear, (this is just over 8000 miles worth of wear in about 19 years !!
Area cleaned up & ready for the new sprocket.
And new sprocket fitted. I'll tighten the bolts up & wirelock them when the chain is back on as it's easier to hold the sprocket then.
Latest due date for my rear sprockets is end of December !!
