749s Temp Sensor Error code 4.1
netaron
Hi All,
My 2003 749s has been great until the oil cooler started to leak. It is a long story, but the dealer basically overlooked my request for the recall service 4 times over the last almost 2 years to replace the oil cooler.
Once the oil cooler started to leak, oil found its way into the CPU area. The first clue was the engine light coming on, and the error code displayed was "4.1 air temp shorted to power supply." I replaced the air temp sensor, but still no go.
I measured the wires going to the temp sensor for voltage and shorts, and it doesn't seem shorted as the resistance reading was very high. I also checked the wiring to the best I could, didn't see any issues.
Next I removed the CPU, there was no oil inside the contacts, cleaned all the oil out of the CPU box, sprayed wires down with simple green and rinsed everything out. Using a heat gun with low temp, I dried things out and let it sit for three days.
After hooking everything up, the engine light is still on with error code 4.1.
Since I have a full termi exhaust with the performance CPU, I swapped out the original CPU, still no go.
Next I removed the instrument panel, checked contacts, all looked good. I followed the wiring diagram to the instrument panel in the Ducati shop manual, but I am not sure what color the wires are for the temp sensor going to the CPU.
Finally I had the recall work done swap out the oil cooler. The dealer did not want to take any responsibility for what happened after the bike started leading oil and apparently caused the air temp error. But I can say for certain that was what caused it. Regardless, I'm at a loss here, any ideas are much appreciated!
Aron
This is not as straight forward as it seems. The air temperature sensor is mounted in the RH side of the headlamp housing and, as you have seen, it's wires go to the dash. The signal is sent from the dash to the ECU via the CAN line, pin 20 (CAN+, red/white wire) and pin 29 (CAN- Red/black wire). It is unlikely that there is a problem with the CAN line or you'd have a whole lot more errors.
The sensor has a green/red wire (signal out) and a black wire (ground). "Air temp shorted to power supply" could in fact mean that it is missing the ground connection which would be a good place to start. Check that the black wire is indeed making a connection to ground.
Although the ECU was covered in oil I doubt very much whether this is cause of the problem with the air temperature sensor
Well if there is continuity in both sensor wires back to the dash then the problem may well lie with the dash itself.
I forgot that I had actually done the continuity test from sensor to dash a while back; I also checked all the other pins/connections at the dash plug to make sure it was shorting with anything else, so all checked out fine. Is it possible water could cause damage to the dash? I did place it outside in the sun to dry out, but that did not help.
It seems the only thing you haven't done is replace the sensor itself. Might this be your next course of action?
Yes, i just re-read your original post. It does look like the problem could be with the dash.
Ya, you may be right Derek; I'm curious to know if anyone has been able to actually open the instrument panel as it looks to be a glued-shut unit.....
