749 Fuel System Relay Question
stirrup
Got the battery box off my 749 (and about half the rest of the bike too judging by my garage!)
Checked the fuel pump relay dangling at the bottom left of the box after several tips here. Yup, corrosion starting. Only been on the road a year....
Question is, after cleaning it up whats the best tried and proven fix to prolong it's life?
Thanks
Last time I had the battery box off I cleaned every thing up and sprayed all the bits with Halfords Silicone spray, I haven't been back in there since. other electrical connections I have also smeared with Hepworths Silicone grease, at £10 for a small tub it aint cheap but considering the amount of water my bike has endured including being swamped with sea water from the bow waves of the Mallaig ferry it seems to be doing the trick....
might also be worth checking the lighting relay up inside the headlight housing, need to remove the nose cone and black splash gaurd to access it, this was totally corroded on mine but i opened it up, cleaned the contacts and sealed it over with the silicone grease too...
Thanks
That relay has caused me & a few other problems a few times, keep a spare 1. theyre buttons.
If your headlight or fuel pump relay goes south and you dont have a spare, disconnect, give it a good solid tap, and try it again.
As likely as not it will be working again. Done this 3 times on 3 different relays;).
Take care,
Frank
I turned mine the other way & covered it in self almalgamating tape. If you look there is Then i used its original holder to house a spare one just in case that one failed on a rideout
