749 battery voltage
stirrup
What voltage do you see at switch on with your 749/999? Mine shows 12.5 and drops as low as 12.0 if I don't press the starter before the lights go off on timer, the recovers to about 12.3 ish.
Despite being on an Optimate all winter the original battery faded away. Now have new Yuasa. Fully charged overnight before fitting. Had a couple of 50 mile runs out and used the Optimate in between.
Beginning to wonder if I need an Accumate which I think has a higher charging current, but I thought Optimate was supposed to be fine for this battery size and duty.
Ideas? Maybe I'm faffing about nothing....
999s, got it on an optimate III plugged into a timer so it comes on between 6:30 and 9:30 everyday. Recommended not to leave it on 24/7 - even though the optimate intelligence is supposed to check the settings every hour or so.
After the lights have done their run through the voltage drops to 11.6
Still fires up no problem with one jab of the starter switch - starter keeps going till it fires.
After that, voltage rises up to 13.8
Ive never bothered with an optimate, only needed a charger this weekend coz of the lighting relay failing. my battery has always been fine although it rarely goes a month without decent use. longest its been left is prolly 4 weeks and it started fine. I know alarms will cause a drain on them but again, not someting i bother with. mine tends to show 14.3 - 14.4 volts when running and never lower than 12.5 when first switched on.
Thanks for the replies guys. Sounds as though I'm looking for a problem I haven't got. Idea of timer on the Optimate sounds a good one. Certainly didn't save the first battery having it on all the time....
