748 to 916 engine conversion
BryanWalker
Hi guys when I got my 748 the other week the guy told me there was a slight leak from the base gasket, today I found out that the leak is more than just a leak after an hours worth of town riding there were quite a few drips under the bike :(
So the reason for this post is....... Can I fit 916 pistons, barrels and chip to my 748 or would I need to use the 916 crank aswell? I did want an 853 kit but cant afford the £1395 price tag :(
cheers Bry
Welcome pal,
Before you do anything, be sure its the base gasket. It could be the oil pressure switch as these can cause a leak, also wipe clean the area around the base as it could also be the breather as the leak when knackered.
ref the switch, i understand you can switch the barrels and pistons, everything else remains the same, but adding a power commander does a better job than a chip.
i think that will make it an 853 anyhow (from what i understand anyways) - plus replace your base gaskets!
You can use 916 barrels but you need the pistons from the 853 kit. The height of the 916 piston plus its wight is wrong as I understand it.
Thanks for the replies :) there is a pool oil collected in the indents behind the rear cylinder, so I assume its the base gasket. Once the engine is out of the frame I will inspect it better. I think in the long run I will be best saving up to get the 853 kit as it has everything needed in it.
There is no base gasket, the 'gasket' is a shim to set the squish height and the seal is made with 3-Bond sealant. Leak is most likely from the o-ring that seals the blind oil-way. Blank off the oil-way with a grub screw while you are in there.
Sorry for sounding clueless but wouldn't putting a grub screw in the oil way starve something of oil?
The oil way goes nowhere, it's a left over from the 2V engines which share the same crankcases. The only thing that would get starved of oil is the leak :D
haha cool, I am going to order a new shim and some 3-bond sealant this week, aswell as getting a grub screw and fix the leak. Then start saving pennies for the 853 kit :D
