748 Swing arm / engine bolt.
Silver-Surfer
Hi all
Only one bolt stopping me from getting the 748 engine out. Its the swing arm pivot / main engine bolt. Got the right side off but the left side has an allan screw head (not sure what the real name is but you know what I mean) what size is it ?
Any help would be good.
Thanks
SS
I forget the size but the spindle caused me no end of angst when I rebuilt my 748 5 yrs ago. The Haynes manual shows a finger effortlessly pushing the spindle out.
I ended up with a 10 ton press.
Good luck !
I enclose further details previously penned, see below.
ShedBob
You remember my excited gibberings about buying the unfeasibly cheap 748 ?
You may even remember how it was going to involve a good clean, maybe a respray and a set of clutch plates. Nothing fancy, nice & simple.
And cheap.
And pigs might fly.
If you were to cross my storm lashed yard & enter my equally storm lashed garage you would see a 748 engine sitting proudly upon my hydraulic workbench. Of the other major components to leave Bologna together however you would find surprisingly little sign. The tank & bodywork lie in a corner of Davy the Paints workshop in Wigtown. The complete set of Ducati stickers are boxed with little pictures showing where they are to be stuck in my office. The wiring loom is in a cardboard box. Wheels lean against the far wall. The exhaust system pokes out from another cardboard box. Of the chassis there is no sign at all for it moved today to the powder coaters in darkest Bingley. I know this for a kindly man phoned me from there to tell me it had arrived & would I send him £250 to apply some colour to it (ouch). A brand new clutch basket sits on the bench awaiting me figuring out how I'm going to hold the old one steady while I get the bolts out of the sucker. Various new bits are winging their way here even now including a new sump plug to replace the butchered one currently "fitted". I've got to figure out how to get that off too. Stainless fasteners are ordered. Alloy fairing bolts & Dzus fasteners from Busters. There are even 2 genuine Ducati washers in my wallet. Because they are Ducati racing components this explains why my wallet feels so light. Maybe.
So how did I get here. Enthusiasm. Overenthusiasm in fact. When you take bits off a 6 year old motorbike you find scuzzy old bits lurking underneath. So you take them off too to give them a bit of a clean & there's more grotty stuff put on display. Before you know it you're deep in the doo-doo & looking for lots of biscuit tins to put all the bits in. Then you buy a parts washer from Screwfix & a gallon of Gunk. And little wire brushes you can mount in the drill which take skin off in a millisecond. And a polishing kit ditto. And cotton rag stuff that comes on a roll for wiping. It all starts to get a bit out of control.
Consider for a moment the swinging arm. A handsome component, remarkably light for it's size, it jutted proudly from the back of the engine/frame unit. By this point I'd removed everything else behind the engine so perhaps it was unduly prominent. Bits sticking out always attract attention, good & bad. Ask that Jordan Wumman; she knows.
But where engine/frame & swing arm meet is the muckiest bit of any motorcycle. Chain oil & road gunge combine into automotive gloop you can't get out with the special blunt screwdriver I keep for probing such rank depths. So when chatting to Bonny on the phone one night he suggested that I might want to inspect the back of the arm for chain damage. This was all the encouragement I needed. Bonny knows all things I believe. If he said the swing arm was to be removed then remove it I would.
It goes downhill from here.
Being a sensible fellow I first consulted my Haynes manual. It was very helpful. First remove engine it said. Otherwise it all seemed perfectly simple. Undo & remove lock bolt on right hand side. Then slide out spindle to the left. There was even a picture in the Haynes book showing spindle emerging smoothly into the light propelled by the Haynes finger of awesome power.
Only mine wouldn't. Spindle & finger refused to interact in the approved Haynesian fashion. It seemed stuck. It was stuck in fact.
It was time for the big hammer. Well actually I worked my way up to the big hammer via an Estwing claw hammer (a tool of considerable beauty), a brass & hide mallet (less so), a 4lb mash hammer (ugly) until I found myself laying on with a fencing mell. All were equally unsuccessful. So I got my Dad to turn up a sized drift on his lathe & we ran through the hammer routine again. Nope. Time for the interweb. Helpful man in Nottingham suggested a draw puller running through the middle of the hollow spindle which would pull spindle to the left while I bashed right hand end again. This was a good idea. Maybe made about 4mm on it this way. Then it seized again. Heat didn't work. I sat up in bed one night when the plan of using the wart clinics' liquid nitrogen to shrink the spindle hit me. In short I was getting desperate.
It was time for Rodney.
I may have mentioned Rodney before.
All amateur mechanics need a go-to guy. He's the fella for when you're just plain stuck. Rodney is my go-to guy.
Needed a van to pick up bench from Jane. Rod's the boy.
Jeanne's Jag not charging. Rod fixed it.
He's like Ghostbusters with a thick Wigtownshire accent & a fondness for anything with an engine. If it's loud & snottery so much the better. Ducatis fit this description.
So after a bit of telephone triage he came over in his Dad's wee van with a big hydraulic puller thing he uses to pull shafts out of combine harvesters when they break down out in the fields. It wasn't big enough. Special freezy spray no good. More hammer work. Nada. So we pulled the forks out of it, picked the whole thing up, slung it into the van & Rod trundled away into the night to his garage. Once there he drilled the spindle until it began to deform then picked engine/frame/arm up with an engine hoist turned the entire thing on it's side & inserted it carefully into a 10 ton hydraulic press. And with only 8 tons of pressure the spindle slid easily out just like the manual said it would.
Simple.
He phoned me up a day or two later.
"Ye'll have tae take this thing away. My Dad's been drawing diagrams of how Desmodromic valves work for the Irish lorry drivers & they want to take the engine tae bits tae see if he's richt. Oh & I steam cleaned the engine & frame while I was at it."
I believe he may be some kind of saint. He wouldn't take any money either. Definitely a minor deity of some sort.
So that's why my lovely bike is in a million bits. Judicious application of heat & hammers is partly why the frame is away for refinishing. I've realised that it may be a poor match for the wheels so they may need doing too. There's some brackets could do with some chrome as well. And I've found a few more chewed fasteners.
Christ I hope I like riding it.
Bastid of a thing to get out if they are stubbon. I've done 2 now and both of them were murder. On both of them I was able to get the pivot out about halfway and that was it. I literally chopped it in half and had to send it back though the way it came.
Good luck
Does it screw out or simply slide ? Once you have taken the nut of the right hand side whats the allan head bolt for ? Is the rest of the pivot threaded or is the allan bolt just for tightening it up once you put it back in ?
SS
SS
Its just for re tightening. There are no further threads inside.
well i don't fancy that operation, well maybes
but thats a great story and a great piece of writing mr, Shedbob.......:)
Ouch !
Well here is a laugh for you !
Had a go at getting the bolt out last night. Used a 6lb sledge hammer. It was starting to move very very slowly until I hit my finger with the sledge hammer against the frame !! BANG
Up to A&E - I have broken my left index finger in two places !!!
That will put a stop to the garage work for a while ! !
SS
Sorry..... couldn't help but chuckle a bit at that!.....:o:o:o
Hope you recover quickly and take a bit more care removing the bolt next time.;)
Thanks - thoroughly enjoyed that story. Reminded me of a similar situation on my F650 about eighteen months ago. :D
Good to hear that other people can do silly things as well !
Getting better, I can bend my finger which should make changing gear easier ! It was a hard week riding the bike to work with a broken finger and only being able to use the three !
SS
Has been about the only positive side of my ongoing engine rebuilds with my bike.......the pivot bolt is that lubed up and recently installed it does slide out effortlessly (unlike the first time I had to remove it).
Good luck and hope the finger's better.:comp2:
I made a tool for removing mine and it came out in 15 mins.
Threaded rod , aluminium plate , 32 mm socket and 2 nuts.
jobs a gooden
geo
