hi everyone
just bought my first ducati 1999 748
i need help with the rear paddock stand i purchased from busters ,the spigot with the orings on is to big to go into the rear axle
has anyone had the same problem or got any ideas?
thanks in advance
dave.
The spindle has two sizes smaller dia for the sprocket side, larger dia for the wheel side
is the spigot a fit in the other side by any chance ?, i have two stands for the rear for which ever side
i require to work on.
You might need another pin for the stand?
it has a larger side and a small side
the small side has 2 bearings on it which make it the same size as the large sid with a circlip holding them on on the end
the large side has 3 rubber orings behind like a large washer with a thread in it with a threaded bar running down the inside with a nob on the other end to tighten it up so the orings sqwash and swell for better fit i assume .
so if i want to use the narrow end i have to remove the circlip and bearing first.
if this doesnt make sense i will post a pic
Concur with previous comments but also note that you should have the spring loose before inserting into rear axle...you then tighten up so the o rings 'lock' it in place
thanks for the replies guys
i have measured the inside dia of the rear axle and thats 30 mm
the spigot on the paddock stand is almost 32 mm outside dia
is the axle on my ducati an s aftermarket item ????/
No, you will need to get the spigot from the supplier (Busters) which has nothing to do with a Ducati frame number. Call them. If the bike is ex-race anything could have been fitted. It's the stand which is aftermarket rather than the axle, probably.
Just in case,the paddock stand goes in from the sprocket side, at which i believe, the rear axle is wider in diameter than the side where the wheel nut goes, :thumbs:
sorted it now guys,busters sent out the wrong spigot
ive been intouch with busters and they have sent me the correct spigot out
cheers for the help fellas.
dave
