620ie wont start! Help Please
arrancolin
Hi there
Have not had my 2003 620ie Monster long (am new to Ducatis too) but have done 1000 miles or so. Anyway its been laid up on Optimate charger for a month or so and when I go out to start it there is no familiar click when I press the button to deactivate the immobiliser (and alarm which was fitted by a previous owner). When key in and turned, everything flashes and the clocks turn and go back - then nothing when press starter - as if still immobilised. Have looked at posts, and checked wiring, fuses and even changed the immobiliser ring at the ignition key assembly. Still nothing. Have tried by passing the immobiliser but the EOBD light does not flash as it should - flashes and then goes out and stays out. Only thing I can think of is the battery for the transponder but then neither key works. Have put in the red key to test the immobiliser system but this shows that system is working normally.
Anyone any ideas? its a long way from here to Ducati Glasgow! Would really appreciate help.
Colin
:welcome:
Can you hear the fuel pump priming?
Does the starter engage when you press the start button - it's not clear from your post?
Thanks. Alarm? - please explain. It is fitted with a meta alarm and it is certainly not doing anything just now.. I dont know anything about them and if I knew how would be happy to take it off and sling it.
Check to see if the in-line fuse for the alarm is OK. If it has blown the back up battery will have run the alarm until it was flat.
Also, i think Meta alarms require the ignition to be on to take them out of sleep mode, ie ignition on/press alarm fob.
Found the manual online
Exiting sleep mode
-To exit sleep mode, turn the ignition on.
-Disarm using remote.
-If the alarm entered sleep mode from a fully armed state, it gives a 5
second pre-alarm beep signal to allow disarming before sounding.
-If, after the 5 second period, the system is not disarmed with the
remote, the siren will sound.
http://www.metasystem.co.uk/index.php/msy_eng_en/content/view/full/2504
Thanks Chris - will try this. Have downloaded instructions as per link. Any idea where I might find a fitting instruction so I can get shot of the damn thing?
Colin
Try looking near to where the connector is for the ignition switch into the loom. There is a permanent 12v feed there and the last alarm I removed had tapped into the wires there. Look for one of those inline holders for a blade fues, the ones with a rubber cover over the fuse. The fitting instructions aren't normally posted anywhere for security reasons. I removed mine by finding where it had been tapped into and bridged. I then matched the wire colours and reconnected the wires using solder, heat shrink and same gauge wire. You should find they have tapped in for +12, Ign 12v, indicators and -ve and bridged 1 or 2 circuits, ie Fuel pump and/or starter
Hi Chris
Thanks for your advice.
I have traced the wiring for the alarm (having found a picture of one) and it seems to tap into the system under the tank where wiring passes into the bottom of the fuel tank (low fuel sensor?). I can't see an inline fuse anywhere though. It seems to come down from the alarm unit to a junction where wires go to the positive and negative terminals on the battery, one then goes off to the rear of the machine, and one over to the other side where it is tapped into the loom as described. This is a pretty crude description and I must have missed wires that go elsewhere. Would it be safe to remove it ? Would there be any implications I have not thought about?
Colin
Further problem - cant remove alarm as owner who fitted it helpfully binned the original Ducati code card. Will have to trace fault and try and fix.
Most alarms are designed to immobilise both the fuel and ignition circuits.
It you are competent with auto electrics you need to locate the power feed, the earths, and the wiring that makes the indicators flash. These wire can be easy removed or cut close to the point were it joins the loom.
The wires to the flashing led can be cut or just pull the led from where ever it's held and unravel.
Next trace the ignition and fuel circuits and cut these wire too but you probably need to bridge the gap with additional wires.
If you don't feel confident, entrust it to someone else.
Good luck
Hi Chris
Is it tapped or bridged? Tapped = piggy backed onto the wire, Bridged = wire cut and joined to two wires from alarm
Sounds like you have found where the alarm has immobilised the fuel pump. By matching up the original wire colours and rejoining you will restore the fuel pump circuit (remove alarm wires first)
Hi - your help is brilliant and should help me get going again.
If I remove the alarm would I have problems with the original Ducati equipment? The Ducati code card for instance contains the information needed to override the immobiliser and this has been replaced with a Meta Alarm code card. I am new to this type of equipment (but learning fast).
Colin
The code cards are two separate things. The Meta one relates only to bypassing the alarm. The Ducati one is for bypassing the ECU immobiliser. Get rid of the alarm and it's code card is redundant The Meta alarm (being Cat1) should interupt two circuits, usually the fuel pump and the starter. If the installer did a good job he will have cut a section out of the wiring so that a Tea Leaf can't trace the wires back and just twist them together again.
Ducati say the card can't be replaced if lost, however there is a guy who advertises on eBay that he can retrieve the info from the ECU/clocks/Red Key (very expensive). All is not lost as keys can be cloned and immobilisers removed if necessary (not so expensive).
Hi Chris,
Have now removed Meta Alarm - it had two tapped connections and two bridged and it did have an inline fuse hidden away. Have restored connections with japanese connectors. Only wire cut was the one to the LED at the back of the bike (which remains in place) so if anyone wants a faulty Meta Alarm let me know.
Anyway the good news is that the bike now starts and everything works as it should. Thanks for all your help, advice and suggestions (and others).
I now at least know that what the Ducati code card I dont have means and I have learned a few other things along the way.
Having owned Brit bikes for past forty years or so and done just about everything oon them, owning a Ducati looks to be a whole new education!
Thanks again.
Colin:)
And the 620 ie are cracking wee bikes,had mine foe over 6 years now and use it as my winter hack,but still have great fun on it,and you can surprise a few of the "bigger" Dukes if you keep it in the sweet spot,only trouble i'm having at the moment is the electronic rev counter-stuck at the same bit-enjoy it anyway.
