The new collets bed in and if you look carefully at a used one you will see that they have slight wear lines where they contact the valve groove and the closer shim. So replacing the collets will close the clearance by a small amount which will open up over the next few thousand miles. Unless the collets have broken (this can happen if the gap is in the big side and the engine gets revved hard) I would leave the old ones. You should also try to put them back in the same way up.
The inlet opener clearances should be .004-.005", with a minimum of .002" - aim for .004" when setting them. (Sorry but I work in old money for measuring clearances)
The exhaust openers should be .005-.006", again with a minimum of .002", aim for .005"
All the closers should be between .001" and .002", aim for as near to 0.00 as possible. With the belts off you can rotate the cams by hand and will easily feel any binding. The shims come in .05mm (.002") increments, so if the closer gap is .002 or less leave it alone - or you can spend a lot of time grinding them by hand but there is the risk of making them uneven.
In use, as the valve seats wear, the closer gaps will get bigger and the openers will get tighter so it is best to set the closers at the minimum clearance specified and the openers at the maximum. Although on an older engine with worn valve guides/seals carbon from burnt oil can close the closer gaps.
