1200 multi MAP sensor
Ger
Well-known member
Thought I'd just post this for reference.
Bike displaying "errors" ...."engine".
Got melcodiag connected up ...yep horizontal MAP malfunction.
Got the sensor off the bike noticed water in the input pipe on the sensor....gave it a whiff of airline and water blew out .....gave the pipe same ....refitted faults would now clear and errors no longer on dash display.
Gerr
Update..one hundred miles later bike briefly displayed the error again ....then cleared.....bike had been fine all day. About 3 miles later bike became unrideable. It ticks over ...starts ...however any load whatsoever it misfires cannot pull away. If I'd had tools with me I would have disconnected the sensor hopefully making the bike throw an error again and might have been able to ride the bike home.
Was recovered by breakdown truck on Salisbury to Wilton road yesterday evening.
So I'll replace the sensor. I will do some checks on it out of curiosity using a fast evap cleaner and check output voltage Vs vac.
A few bikers stopped to see if they could help get me drinks or food etc ...as they'd noticed I'd been stuck there for a few hours. Nice young lady stopped in car also asking if I was ok....can she go get drinks for me etc. Renews faith in humans. One guy on a Triumph rocket stopped ...said he'd reluctantly got rid of his Diavel due to electronic unreliability ....MAP sensors. :unsure:
I’ve replaced loads of MAP sensors on Multis, Panigales and Diavels. I don’t think it’s a Ducati issue per se as the sensors aren’t made by Ducati but are Bosch or other reputable makes and are the same as used in loads of cars and on other bikes. I suspect it’s just the usual heat, vibration, heat vibration etc that breaks them down quicker in bikes than cars.
Yeah ....I agree ..
If you think about this MAP sensor fitted in a car application.....it's in the intake manifold.....four pots a smooth ISH pulsing pressure...... Think about it in the Duc ... Right in the inlet stub ...on the valve side of butterfly ...600 cc piston just the other side of the valves which are inches away.....it's little silicone diaphragm isn't going to have a quiet life ....also if the bike coughs back through the inlet as they do now and then ... those are going to be high pressure pulses......maybe that's why the big twins bugger them up ?
Seeing as it's raining .. thought I'd bodge up a connector ...and see what the sensor is doing ....it does produce stable voltage dependant on amount of vaccum or pressure I apply .....obvs no idea how much pressure or vaccum I'm applying....so I'll still need to get a new one .....
Ahhh ...the old Farnell bench power supply....dual output 30v 2A ....fully variable including current. You can get bench power supplies on eBay...mainly single channel ..probably some dual ones.
Does anyone know if the bike recalibrates itself when a MAP sensor is replaced ... @Nelly or this is done with the Ducati diagnostic kit ? ... Most of the tests don't work for me on my melco diag including the MAP sensor tests ....
I'll be sending the Amazon MAP sensor back for refund ..... doesn't fuel right at low speed neutral throttle.......bike is in bits at the moment too ....I'm part way through Desmo Service. What a bloody faff. Luckily I have a bike lift......I can't imagine doing this without the lift.
Well I've checked all the clearances ..,..all in spec ....one closer just in ......a right bitch trying to get the vertical head cover off ....... The relevant feeler gauges all bent now .....:)..... Now getting pissed ....will use tomorrow as a clean up day ready for putting back together.....have to pace myself now at my age ....plus hangover......
Was that the Germban MAP sensor I told you about or AN Other? Just curious.
Well ....I prefer streaming ....but the 301 was given to me in the 70s by my uncle .....it was In my garage loft for many years and I made a plinth for it with the Jelco arm ....it's now mainly decorative due to quality of vinyl available now ...the 301 still rocks ..,.. quality solid old engineering.....
Real MAP sensor fitted ......still finishing off the Desmo Service ...so not checked yet.
Put a K&N air filter in ...fits bang on ...got good price at sportbike shop in Bris ...about same price as Ducati replacement filter. I did try a pipercross last year. . but sent it back after two attempts for them to send me one which is the correct dimensions.
