1098 Oil Filter
wishaykillie
Just back in form a spirited run and when I stopped in Biggar I noticed a bit of oil under my bike. Took it easy going home the fault light also came on about 3 miles from home.
When I got the fairings off to have a look and found oil leaking from the filter. Ran the engine and sure enough spotted oil droplets on the filter. Managed to tighten it by hand as much as I could (need to pick up a filter belt) but still seeping ever so slightly.
Anybody else ever had this problem?
I managed to get a belt wrench around it and got a good wee nip on it and it seems to have sealed it now. Put a bit of pait marker on it and will give it a check a bit more often than not.
Back tyre's got a fair bit of oil on it now should be fun scrubbing that off :rolleyes:
