1000SSie DS/900SL Hybrid
Nasher
Well-known member
I’ve mentioned my current project quite a lot on the forum and now I’ve ensured it will work to my satisfaction I thought I’d best stick some progress up.
Last summer I picked up a 2003 1000SSie DS for a very good price and spent a bit of time getting it to start and run correctly.
I brought it mainly because the engine is in my opinion a peach, and is the ultimate development of the Classic 2 Valve Aircooled Ducati V Twin. I have a 5 page Ducati pdf which details the technical differences between the 992CC engine and it’s 904cc predecessor.
It’s also fitted as standard with an Ohlins rear shock, and Showa front forks, so has the making of something really nice to play with.
I took the horrid Cheap carbon cans off and put the OEM ones on it came with, threw some Exactfit cables on, sorted out the non-functioning idiot lights, then brought some leads and downloaded the software to reset the TPS – Thanks ChrisW.
I then enjoyed riding it, and it rides lovely.
In fact I’ve had a big guilt trip that I’ve chosen to ride it a bit more than my beloved 1997 Carbie M900.
But I always had a plan, because let’s face it, it’s not as pretty as it’s predecessors.
My plan was to fit a complete set of 900 Superlight Bodywork to it, as in my opinion that would be the best of all worlds as far as this generation of Supersport goes.
I also had all the bodywork in stock already, so it hasn’t cost me a great deal, apart from time.
I’m posting this now, as on Friday I had a big milestone, I’d fitted the Carbie SS tank with a fuel pump, filter and Level sender from a 1000SSie and had it running from the new tank.
Over the weekend I bolted on some parts I’ve been making on and off over the last couple of months, got the fairings mocked up into place, and am now convinced it will all work.
My reason for being reserved about it, is that I’d set myself a goal of doing it all without any modification to the standard parts, especially the frame, as I’d like to be able to offer it for sale at some stage with all the standard parts so it can be put back to standard. Despite being an unloved model it is after all quite rare.
Images of progress with some scant details to follow during the day today and tomorrow as I get time between working from home, and I’ll keep it up to date going forward.
No longer working Fridays and currently not having access to my boat as the yard is in lockdown will really help move the project on.
But this is how it currently sits:
Nasher.
WAYNE
Nasher.
Very nice mate, can't wait to see the the finished machine (y)
Nasher
Well-known member
Hey Darkness.
I'm setting it up with the standard headlight and front/top fairing, and will probably MOT it like that, but have in stock a race fairing section with no headlight aperture, and a single small round projector with Dip and main beam.
Plan is to fit it off to one side.
Darkness
Strangely enough, I do actually have a Powerbronze twin headlight unit and fairing section that I keep going to sell then don't to keep my options open with this project.
I wondered if you still had it: I remember one of your listings where you clearly weren’t really wanting to let go! 😉
Nasher
Well-known member
As mentioned the bike came to me fitted with a horrid pair of Cheap and Nasty Carbon Exhaust cans, which sounded horrible.
But when I picked it up the previous owner gave me the original Standard exhausts, and I ran it about with them on for a while.
I then picked up a pair of Ducati Performance Oval Remus Exhaust cans from Ebay that had been fitted to a 900SSie.
I knew these would look and sound good as I have exactly the same fitted to my M900.
They didn't however fit, the hangers being about an inch too far back to work, but as I really wasn't impressed with the look or quality of the standard DP hangers I decided to make my own. The DP straps also connect the silencers direct to the frame with no rubber mounts.
I used a pair of aftermarket Superlight frame mounts I had from a previous build, then flattened them out so I could make up some simple triangular Aluminium plates that bolt to the silencers, and used a pair of Standard SS rubber bobbins between the two.
Nasher
Well-known member
At the same time as the exhausts I sorted out the rear mudguard etc.
The bike came fitted with more horrible tat.
A Red Fibreglass undertray with rusty numberplate and indicator mount. The original undertray/tooltray was in place above the Fibreglass one, but had been cut to fit the tat over the top.
There was also no Numberplate light at all.
It all looks OKish in this image, but was awful, and the numberplate has a nice rub mark at the bottom where the tyre had touched it.
I managed to find a standard undertray and mudguard/numberplate mount on ebay for almost nothing as they also fit the 900/750SSie, and so many people are breaking them or turning them into unfinished projects.
I fitted a pair of later Ducati indicators which I had in stock, plus another pair at the front to replace the again horrid, tacky, cheap arrow shaped ones fitted.
It seams odd to go with standard OEM rear guards etc, but they do look so much better and add to the illusion of it being a 900SL.
I should add at this stage, that as well as the Ohlins rear shock etc, the 1000SSie is also fitted with really nice 5 spoke wheels as standard.
Nasher.
Nasher
Well-known member
My eventual plan for the exhausts is Spaghetti type headers to go with the Remus DP cans.
Not wanting to pay the asking price from the usual sources I've done my research on where to put the balance pipe and want to try making my own by cutting up a set of 900SSie standard headers to remove the cruciform and adding in bends and a link pipe cut from a couple of rough sets of M900 and 900SS headers I have. I've been collecting images of various Spaghetti headers, and honing my TIG skills with my new gear before giving it a go.
It's not that I think the likes of Madasl charge too much, I just don't want to pay almost what I paid for the bike for a set of headers.
I did come across a set of Sport classic headers on Ebay local to me and brought them on a whim thinking they'd be easier to modify.
But when I collected them I realised they are double skinned so would be difficult to add a proper full sized link pipe to.
I might still see if they fit, they should do as the SC has the same engine.
When I fitted the exhaust cans I also dropped in a K&N Air filter, and it did appear to run a bit better at higher revs, but when it's back on the road I'm going to try and get it on a dyno. it would be nice to try these SC headers to see if they make any difference, but will probably stick them back up on Ebay before that and see if they sell.
Nasher
Well-known member
The other thing I've added, just a bit of bling really is a DP Clutch Pressure plate and open cover of unknown origin.
I had them hanging around having taken them off my last 900SS project when I sold it, as despite the engine mods the buyer wanted it as near to standard as possible, hence a lot of stuff I took off it will be used on this project.
I'd actually forgotten until I posted this about the trouble I had with the clutch which made some odd noises and was found to have lots of metal plates and no where near enough friction plates, despite the recent invoice that came with the bike from a dealership for replacing the clutch basket.
I rebuilt the 'stack' correctly using spare friction plates and normal dry clutch clattery noises have been resumed.
Note the Exactfit cable seen in the image which I fitted despite having the tooling to crimp my own battery cables.
When I worked out what I needed to spend on cable and fittings etc, and being in a rush to get it to start the Exactfit cables were worth trying.
I didn't however piggyback them, I removed the old cables and remade the ends of the smaller cables that fit to the battery instead.
Nasher
Well-known member
Moving on to the tank.
I did consider leaving the 1000SSie Tank in place but decided it would look too odd even if I removed the ugly tank pad from the rear.
I was lucky to pick up a Carbie SS tank a few years ago for a reasonable price, and even more lucky when it arrived that it isn't rusted out at the bottom. The external paint is very good indeed.
I did however spend some uncomfortable time with my hand through the hole getting rid of as much internal surface rust and loose paint/sealant as possible before converting the rust with KURUST from Hammerite.
Mechanically it's very easy to fit to the later 1000 frame as the positioning of the rear hinge mount and front pads are exactly the same despite the intervening years.
It's best to describe this with diagrams stolen from the Stien Dinse website than with actual images.
The rear hinge mount on both tanks is interchangeable, the only difference being the 1000 one only has two holes to mount to the frame, but the 900 one has 3.
But the 2 rear most holes in the 900 bracket do match exactly the 2 holes in the 1000 frame.
At the front the 1000 frame has two rubber mounts bolted to it whereas on the 900 the rubber mounts are bolted under the tank.
If the mounts are removed from the 1000 frame, the 900 rubber mounts sit perfectly on the frame, which was excellent news.
At the front the 900 has a mechanical over centre latch to clamp the tank down to a hook on the frame.
On the 1000 its a simple rubber strap that clips over a pin on the frame and then stretches over a 'Nipple' on the tank. See above.
I wanted to use the 900 style fixing. so simply made a new strap for the 900 latch using a length of 2.4mm Dia Stainless rod which locates over the pin on the frame.
Next post will be the fuel lines etc.
WAYNE
On the 1000 its a simple rubber strap that clips over a pin on the frame and the stretches over a 'Nipple' on the tank. See above.
Great work there and totally agree with Kurust it is the dogs bolox, my 900ie tank inside when i bought mine was horrendous cleaned all the crap out new fuel filter and gave the mesh filter located at the bottom of the fuel pump a good clean, a completely different bike, the IE models are renowned for internal tank corrosion.
(y)
Nasher
Well-known member
Having the tank in place on the frame isn't any good if you can't get the fuel from it to the injectors.
The 1000SSie DS tank and 900SS Carbie tank are actually set up really similarly inside.
The only real difference is that the 900 tank has 3 outlet/inlets:
And the 1000 has 4:
But two of the 1000 tank connections are both breathers, and connect to a 'T' Piece in the breather pipe just a couple of inches from the tank.
So pipework wise I used the single breather pipe from the 900 tank, connected the high pressure pipe for the injectors to the 900 fuel tap, and the HP fuel return line from the injectors to the 900 return pipe.
The only thing that remains to be seen is if the 900 fuel tap can handle the injection pressure long term, but it's been OK so far.
The 1000SS Fuel level sender uses exactly the same thread as the 900SS one, so simply screws into position ready to connect to the 1000SS loom and also supply power to the Fuel pump inside the tank.
The Rubber sleeve inside the tank that the fuel pump sits in is the same part number for both the 1000 and 900, so getting the proper HP pump in the tank is again a simple case of removing the 900 one and snapping the 1000 one into the clips. I did however have to shorten the flexible pipe between the fuel filter and the internal hard pipe by @10mm. But that's the only modification needed to fit all the 1000SS injection tank internals into the 900 Carbie tank.
I'd even picked up a complete set of internal parts from a 1000SS being broken a couple of weeks ago, so didn't have to remove or modify anything from the 1000SS tank. Any tips on storing the 1000SS tank so it doesn't go rusty inside without filling it with Fuel? It will be in my loft shortly for as long as I have the bike.
It was nice when all this that had seemed too easy was proven to work and the bike started and ran from the new(old) tank.
Nasher
Well-known member
I should say at this point that probably all of what I've done is applicable to convert the 900/750SSie as well as my 1000SSie and I assume the 800SSie
There are many differences between the 900/750SSie and 1000/800SSie ranges, but apart from the many mechanical changes to the engine they are mainly electronic.
The use of the later ECU range for example, and the ECU and clocks being dependant on each other with regard to the Immobiliser, unless you get the ECU re-flashed by somebody who's able to disarm the immobiliser.
I was going to get this done and use a set of 900SS instruments, but at the moment I'd rather get the bike on the road and consider that later.
The 1000SS tacho being run from the ECU, and the Speedo again going through the ECU and driven from a rear wheel sensor means a combination of using electronic clocks in the 900 dash or perhaps dropping a mechanical speedo drive in the front end.
At the moment I'm happy with the look of the 1000SS dash, but might decide to change it later.
WAYNE
And the 1000 has 4:
I have not tried it myself but there are loads of vids on Youtube of using cider vinegar for cleaning out rust and also filling the tank with cider vinegar if you intend to store without it rusting out, take a look on youtube or just google.
Pilib
I own two 750ss ie's so perhaps i'am a little biased but i have never liked the slab sided models. Now they look dated and dare i say it 'a little of their time' People even said the 749 and 999 were ugly, Perhaps beauty really is in the eye of the beholder?
Nasher
Well-known member
And the SL style seat unit.
I had left over from a previous build a Carbon Fibre Superlight Single seat unit that I wanted to use on this bike.
The main issue with using it on a 750/900/800/1000SSie frame is these two sticky up brackets that prevent the SL seat unit going down as low as it can to the frame.
My strict rule of not modifying the frame was nearly broken here, but in the end I stuck to my guns and decided to measure carefully and put up with the seat being around 20mm higher than it would be relative to the tank on a genuine Superlight. I raised the back almost the same amount and it looks OK.
At the front I used a pair of spare Carbie Tank rubbers and fibreglassed in a platform for them to bolt to.
Note they are sat on 20mm high spacers, so if I do decide to remove the brackets I can also drop the seat.
The front of the seat unit bolts down to a bracket I've added which connects to the frame using the tank mount bolts, and the seat unit through the front two standard mounting holes:
When I'm happy with everything I'll drill out the captive nuts on the rear of the bracket and insert a pair of standard rubber mounts.
the other two mid-position standard seat unit mounting holes will be filled with dummy bolts and cup washers as I'm securing it right at the back, something Ducati should have done in my opinion.
The holes mentioned above can be seen and made sense of here:
The rear was a bit tougher to achieve how I wanted it, especially as I wanted to use a pair of very small but still legal LED rear lights.
So I reverted to my knowledge of classic MkII Z1000s, where the rear of the seat unit is slid on to two pins which pass through holes in the seat unit with Grommets in them.
The bulkhead I glassed in, and grommeted holes can be seen in the image above of the underside of the seat unit.
So I then needed a bracket to support not only the rear of the seat unit on two pins, but also my chosen small lights, and it must retain the standard undertray and mudguard/plate bracket.
I came up with this:
So that was the seat unit and lights in place.
I wired the lights using standard Superseal connectors to the standard loom.
I'll bolt down the SL seat pad and take some more images later in the week, and obviously I need to paint the seat unit and add some numberboards.
Nasher
Well-known member
last instalment until I've got some more done on Friday this week.
I tried the SL bodywork on the 1000 with the 1000 front subframe in place, thinking it would be easy to buy a 900/750SSie subframe and adapt it to fit the 900 bodywork, headlight etc.
It became obvious that it would be simpler to modify a 900 subframe to fit the 1000 frame.
Luckily the geometry of the mounting points for the two subframes is identical, except the two headstock mounting points on the 1000 frame are wider.
Not centre to centre, but the tubes welded to the headstock are longer and longer bolts are used - hope that makes sense.
This side on view of the 1000 sub frame shows the mounting points:
The frame mounting points have the same geometry, but the fairing and headlight mounts would be difficult to modify.
So I dug out yet another spare from my stash, a rough 900SS subframe, and created a 1000SS/900SS hybrid.
I cut the headstock mount down the middle, splayed it out, and welded a plate in to hold it apart. See below.
I then fabricated copies of the mounting brackets for the various 1000SS electrical items and welded them to the frame.
Main loom plug and socket
Air temp sensor
One of the ignition coils
Instrument cluster
Then gave it a lick of Matt Black paint.
It fitted the 1000SS frame easily enough, and I transferred all the electrical items and loom over:
I started her up again and everything works.
the only thing to sort out is that the 1000SS pilot light bulb holder is too big a diameter to fit the 900SS headlamp hole, but that's easily sorted with a file when it comes off again.
So there she sits until I am off work on Friday and the weekend.:
Nasher
Well-known member
So a little more progress on Friday.
Strangely I discovered that the bottom fairing stays needed to be a little wider for the 900 fairing, and in trying to unscrew the old ones the longer Left hand side one snapped at the top of the thread.
Being Aluminium it was really easy to drill out and re-tap the thread in the cylinder fins, and I made a couple of 10mm longer stays out of some 10mm Aluminium Bar, a couple of Stainless 1/2 nuts and some 16mm Nylon Rod.
The rubber bungs are a really loose fit on the originals and I've heard people lose them easily, perhaps the bars aren't long enough????
So I drilled out the Nylon bar to 9.8mm, pressed it on to the 10mm Aluminium bar, then turned it down to 14mm.
I don't know what I'd do without my Lathe/Mill, it's nothing special but is so useful.
As you've probably guessed the 1000SS upper fairing brackets on the frame don't line up at all with the holes in the 900SS Fairings.
So the next job was to knock up some adaptor brackets.
Shaping them like this is a far better mechanical solution than simple flat straps on the end of the 1000SS spacers, as the shape has the effect of pulling the fairing panels up and In.
As you can see, with the fairing fitted they are not that noticeable, and it's a far nicer solution to look at from the outside than drilling new holes in the fairing panels.
I've put some rubber bungs on the ends of the spacers to stop them rubbing on the insides of the panels.
Nasher
Well-known member
Through the course of the day I managed to get 4 coats of Red paint, and 3 coats of clear lacquer on the seat unit, so it's looking far better than it did.
It's not an exact match, I brought the Red from a seller on Ebay, but it will be good enough for this year as I'm hoping to get all the panels painted professionally over next Winter.
As it was too cold to paint in my unheated garage really, I kept the rattle cans in the house until I needed them each time, and blew the seat unit over with a hair dryer before applying each coat of paint.
It's looking finished in the above images, but the reality is far different.
For a start I've now been let down by two different well known Ducati specialist parts suppliers who claimed to have stock of a Left Hand Front Indicator, took my money then said "Oh, sorry we're out of stock and will send it to you when we have one"
I'm currently hoping it's third time lucky with another supplier, who have at least said they've posted it.
I'm also going to Cut some Number Boards for the seat unit from White Vinyl and add a Black pinstripe around the outside.
Which should break up the mass of Red at the rear.
When I get the seat unit sprayed properly I'll either get the painter to add the number boards in Paint, or use somebody like image works to make up some Vinyl ones printed with a Black Pin Stripe.
You may have noticed that the early 900SS fairings have the Black, White, and Silver Decals, whereas the tank has the later style Gold and White Decals.
Until it all gets painted properly I'm going to try covering up the tank decals with early Black, White, and Silver ones which are on their way to me from Stein Dinse.
The main job I still have to do is strip it all down again, clean up and paint the brackets I've made, and give the bike underneath a good deep clean. It currently looks like it's never been cleaned with the fairings off in it's life.
I'll also do some more investigation into using the Single small Dip/Main Projector headlight I have along with the Race Front Fairing piece that currently has no headlight aperture.
Oh, and if anyone has a good pair of Carbie SS Mirrors in Red or Black that they want to sell please let me know, the ones on the bike are a bit too rough really.
Nasher.
Nasher
Well-known member
Actually, I do have one good Red Mirror, so if anyone has a spare Red one, or two Black ones I'd be interested.
I'd also like to thank everyone at this point for the nice comments and the many 'Likes'.
It's good to know others appreciate the fruits of my addiction.
Nasher.
Nasher
Well-known member
I cut some number boards from White Vinyl today and added a Black line by hand using 3mm lining tape.
Just to see what it would look like.
I think I'm going to have to mask it and spray them with a slightly yellowed off white, as the Vinyl is too White for my taste.,
Nasher
Well-known member
I managed to get the older style tank decals on the bike today.
They cover the newer late 90s ones really nicely and match the fairing decals much better.
I am aware of course that because I've used them to cover up the lacquered-in later decals they are not in the right place, and that the early bikes wouldn't have had the Ducati Logo on both the tank and the Fairing, but at the moment, until a full respray next winter, it looks better than a mixture of early and late decals.
I've definitely decided now that I'm going to spray the numberboards on the seat unit with a slightly off-white colour, and with a wider Black border. It will look so much better, but I need the weather to warm up a little first.
Exige
Go for a pearlescent white maybe :unsure:
Nasher
Well-known member
That's an idea.
I was thinking more of a slightly Yellow or Grey Off-White to add a little bit of an aged look to them, so they are not so bright.
I'm going to have to have a wander down the paint isle at Halfords and find a couple of Wjhites I like the look of.
Top
